disciplerocks's Ford Focus "build" thread
Its a Wolverine. Got it and the pistons from a buddy.
Dang, this is better then a V8 VW bug...
Robert
posted with socks over my hands
So you're not using one of those kits they make?
No, he's fabbing his own kit...
SVT
I'm starting to wonder if he is any kin to Gwaii
Robert
posted with a teddy bear missing one eye.
Those kits are like $2.5k for just the brackets. Screw that.
A little more clearancing to go. Also going to have to mod motor mounts. Needs to go back 2".
So do you just modify the stock cradle basically to accept the reconfigured engine? What are you going to hold the front hubs together with since there will no longer be axles in them, big bolts? Cool build.
As far as the hubs go, I would dismantle the half shafts and just use the part that goes thru the hub, this way it uses the original design used to hold the hub together...
SVT
I'll figure that out later.
Easy, Mustang II front end, they fit every thing, I think some one even put one on the Space Shuttle.
Robert
posted with a milk mustache and a adult book.
