disciplerocks's Ford Focus "build" thread
I'll figure that out later.
I'm the same way. I'll worry about that when I get to that point...don't know if it's good thinking but it's at least on the to do list.
I would look at what others have done and go from there too.
Sent from my A500 using Tapatalk 2
Got the motor moved 1.5" back, made a trans mount, but didn't get holes drilled in car to bolt it in.
Also made it to the junkyard after a starter because I think mine is bad. And I picked up everything except rotors to do my rear disc swap.
Billet flywheel came in, along with my rocker studs.
Trying to decifer the wiring, which is not my strongpoint. The 94-95 Mustang harnesses is a bit confusing. May find an older one.
What ever you do, please please, please do not set this one on fire when welding on it.
Robert
posted with butter and milk, and little bit of love.
Dustin, I'm coming up this weekend, if you want I can modify that harness for you so it will have only the necessary plugs needed, all else will be deleted...
SVT
i have a sedan the i have been collecting parts for im in no rush just geting every thing to getting every thin to gether then start
That would be awesome Rick. How long would it take you?
I can do it in a day, probably 2-3 hours...
SVT
That would be awesome. Hit me up.
I should be in sometime saturday, I'll text you when I'm up there
SVT
Roller rockers and adjustable short shifter came in today.
How much did the rockers run you?
SVT
$123 to my door.
Damn....1.6, or 1.7?
SVT
I dont think the ecu would have liked the 1.7 as much.
Sent from my SGH-T499 using Tapatalk 2
