- Aug 26, 2009
One of the quirks about my "new" 99 Ranger with 4.0 was that the oil pressure gauge needle was on the wrong side of the peg. Today I pulled the dash apart to replace the 6 burned out dash cluster light bulbs. While in there I slid the needle off its shaft and replaced it with the needle resting on the peg. Now when engine is running it's more or less "all over the place", usually very high.
I am going to check the connection at the pressure sending unit, but after reading some old threads on this subject I learned that the OEM gauge is really just an "idiot gauge" so I'd like to know how practical it is to replace it with an oil pressure gauge that actuall registers engine oil pressure.
If I don't discover a bad connection on the existing setup, how do I determine if the problem is the current sending unit or perhaps the dash gauge itself?
coopab
coopab
