- Aug 6, 2007
- Age
- 46
- Western Michigan
- 1975-1995 Ford
See it all the time guys pulling the 4.0 out of rangers/explorers and even after a swap puling them from B2's. And i see the same thing all the time, i want more power. The 4.0 just can't turn the 35's and it lacks blah blah blah. Really crunch the numbers. A stock 5.0L from most donor years esc carbed really isn't that better then a 4.0L power for power. Is it the cool thing? Hey i got a V8 in my ranger/explorer.
Its called gears, rings and pinions. Upgrade your truck with them. I'll take a 4.0L Distirbutorless engine any day over a distributor v8. i run 4.88s and a 4.0L on 36's and i get asked all the time at large events what kind a v8 i have in my truck. Everybody assumes v8 cause i usually make the guys running moderate v8s with 35's look like asshats with their 3.73 gears. I'll just do the v8 swap instead of a gear swap which is what is really needed.
I have always said if i ever put a V8 in any of my RBV's, it'll only be one motor to ever grace my truck and that'll be a Explorer 5.0L cause it distributorless.
just tossing out $.02
i think the one thing i read the most in all the posts thus far in this thread defending a v8 swap is warmed over engines not what i said in the first post. Yeah a built engine is different then a stock engine.
I DID NOT build my truck for pavement pounding, and i am not referencing pavement use AT ALL. But fwiw my B2 on its 36s fawking flys 0-60 mph
and i wasn't addressing you personally it was a blanket statement
