- Nov 29, 2009
- Sheridan, CA
Would it be going out this soon though?Sounds like the bendix is going out. If that's the case it will probably test fine at the parts store. Throw a fit and make them replace it. If they won't go to another shop and get one with a lifetime warranty. Takes time to replace, but you aren't out any $ after that.
That's the thing the. 2 out of 4 were lifetime the other were the ones that had the lifetime warranty.I'm a fan of lifetime warranty parts.
Shim the starter? Never heard of that. And yeah 80 bucks a starter is gettin kinda old.Could be a solenoid or you need to shim the starter. The flywheel can be off just enough to cause an issue. If you can't correct it you will need to take in to a shop and have them do it for you. Don't waste anymore money on starters. Get a good used one and go to a shop and have them check out what is happening. Hope this helps you out, Bro.
