Escorts 2nd SAS
Our maybe go to a saginaw pump. I have been thinking about going that route.
Sent from my SGH-T499 using Tapatalk 2
Yep, that's the plan.
Sent from my HTC SUPERSONIC using Tapatalk 2
Yep. Dug alittle deeper and the link is for 24" plate.
If you get a chance could you tell me the height, width and depth of the winch? Going to mount it before I get the winch and really mount my bumper?
Thanks
Sure. Give me a second.
Sent from my HTC EVO 4G using Tapatalk 2
Thanks
Here you go.
Escorts 2nd SAS
Escorts 2nd SAS
Escorts 2nd SAS
It is time for some steering upgrades.
I blew out the seal on the steering box on my last wheeling trip. Large tires on a stock steering system just isn't cutting it anymore.
This is very close to what I want to do.
Escorts 2nd SAS
This is on an XJ that has a full width 44 or is it a 60.....anyways, I might use 1 ton TRE instead of heim.
Edit: Going to swap to WJ knuckles to have the high steer arm and larger brakes.
Stick with TREs. Hiems was the worst mod on my Ranger. I'm going to TREs this time. They don't chatter and moan and wear out in a month..err....week like hiems.
+1 on the TRE's.
3/4 ton chevy/gmc TREs are pretty stout.
Can I have dibs on getting your current draglink when you do go to swap things over on yours since mine is to long?
If ya want. Don't really know how long it will take.
hmmm hydro assist...
Take all the time you need, no rush.
Are you going to have to redo your track bar seeing as your draglink will be longer or will you be fine?
Now that I remember, I still have access to hydrolic rams that when to a ford 8N, well actually they are mine.
That looks to be a kingpin Dana 60.
I loved my 1 ton TRE's on my old SASd F150. I scored Spicer TREs at a local shop for under $60 for all of them. Used 1.5 OD .25 wall DOM tubing with weld in bungs. Shit was bulletproof.
Escorts 2nd SAS
