- Oct 6, 2007
- Age
- 39
okay....im tryin to figure out what is suggested when installing 4.56's into a 7.5, i have always had to make a small notch on the backside of the RG to fit the pin in it, the reason for doing this is simply the fact that the R&P do not fail usually on the 7.5, it is usually the pin or a spider gear, would u suggest instead notching a already weak pin to fit in the carrier....or instead notching the ring gear to clear.....
just a question in referance to the 7.5" rear i had sold...i notched the ring gear and am told now that doing it that way is incorrect...
