- Jun 15, 2011
- dirty jersey
same here
lol not trying to be difficult here, i was originally trying to help the guy out
So let me guess,
One of you saw the thread and you both joined so you could screw with the discussion.
Been done before. A couple of times with 3in.
Problem?
Yes they will "fit" as long as you don't leave the perfectly smooth asphalt or hit a speed bump at over 5mph.
I have 35's with my camburg 5.5 kit, with fiberglass and a body lift. If you use it right even this setup can still rub when you land unevenly.
I wasn't referring to you, I was more or less talking about the troll.
so by adding everything together, you have 8.5" of lift...
Exactly. You have the BL on top of it. And you're not driving it right then.![]()
I wouldn't say he's "not driving it right", I would say he is just offloading a bit different, cuz if you put major flex on it, or jump the truck, I could see the tires rubbing then. But in Louisiana, we have flat ground. And lots of it :/
not a flat wet grass field, an actual mud hole
According to Scott, flexing won't make it rub. Now jumping it and coming down flat like on the dunes, yeah. Then it'll rub.
a 2wd with a 5.5 inch and a 3" BL will rub, maybe not on the street, but over a bump or hitting an actual mud hole (not a flat wet grass field, an actual mud hole) Im willing to bet it will.
