Post your Camburg 5.5 kit on 31x10.5x15"
Cody Ray
Phoenix
Did a search and found a couple threads but was disappointed with the results. Want to install the 5.5 kit on 31s and wouldn't mind seeing some other rangers. I want to put mine on General Grabbers with KMC XD Enduro 15x7" wheels.
31's will be too small for that lift FYI id go for 33's or itll look like your riding on stock tires with a 5.5 inch lift. just google search pictures
I'm not using fiberglass fenders. The Camburg website suggests 31s with stock fenders. A google search always seems to show me Deaver F31 springs...
mm i had 31's on my stock ranger, id suggest researching the 33's i personally wouldnt be happy with only 31's my buddy had a 3 inch spindle lift and was riding on 33's he had a custom tube front bumper bumper.
cant find any pics tho
with a 5.5 lift you should have no problems putting 35s on it if you wanted to
31's might be slightly small, but considering the Camburg kit gives more travel, you might wan't to stick with smaller tires as you probably don't want your tires being shredded by your fenders or your tires damaging your fenders. Just my $0.02.
hey doyouquaxu you can go f*ck yourself cause you dont know sh!t, i kno someone with a 5.5 lift on 35s
It isn't a 5 and a half inch lift, it is a mid travel kit retard. Don't talk about what you don't know about....
This kit uses a 3″ fabricated race spindles with a massive 1 in Uni-Ball. The upper A-Arm is made with a laser cut pod and 1 1/2″ .120 wall 4130 chromoly tubing. For shocks, Bilstein 5100 series. The springs will provide 2.5″ lift
direct from camburgs site a 3 inch lift spindle with a 2 1\2 inch spring
5.5 inch lift
it also increases travel by about 5 inches over stock
5.5 inch lift
Well do you think you could stuff 35's with 5.5in of lift and stock fenders and wheelbase? No....no you can't
It's a 2wd, and a long(er) travel setup... Stick to 33's unless you like trimming fender or cutting tires.
5.5 inch lift
yeah, 5.5 lift.
5 more inches of travel it does not get. the kit gets maybe 10" tops. i doubt stock rangers get 5" of suspension travel.
So let me guess,
One of you saw the thread and you both joined so you could screw with the discussion.
no i only said that it was infact a 5.5 inch lift i never suggested 35's infoact i told him to stick to 33s
im not the troll here..
*shakes head*
Y'all should quit while your still just slightly behind..
lol not trying to be difficult here, i was originally trying to help the guy out
Upcoming TRS Events
Featured Ranger Based Vehicle
