- Dec 28, 2008
- Wisconsin
Wrong, some counties in the USA don't require emission testing. Therefore, exactly how is it illegal? Also, farm trucks (with farm plates) don't require catalytic converters because it can cause fires.
Wrong...
Your arguement states "In a county that does not require emissions testing/compliance it must not be illegal to remove your catalytic converter". This is FALSE.
http://www.catalyticconverter.org/law/index.htm
States...
Rules for Replacing Converters
In 1986, the U.S. Environmental Protection Agency issued new guidelines for the construction, efficiency and installation of aftermarket catalytic converters. All CleanAir converters listed in this catalog have been designed, tested and manufactured to meet this policy.
In addition, CleanAir converter listed in this catalog is appropriate for use under the current requirements of the California Air Resources Board (C.A.R.B.).
E.P.A. guidelines state that replacement converters may be installed only in the following situations:
1. The vehicle is missing a converter
2. A state or local inspection program has determined that the existing converter needs replacement
3. Vehicles manufactured prior to 1996 must have more than 50,000 miles, and a legitimate need for replacement must be established and documented
4. In cases of OBD Il-equipped vehicles (1996 and later), the O.E. manufacturer's 8-year/80,000-mile warranty must have expired and a legitimate need for replacement must be established and documented.
Please note that Federal law prohibits removal or replacement of a properly functioning O.E. converter.
When replacement of the converter is appropriate (as outlined above), the E.P.A. further requires that:
1. It be installed in the same location as the original
2. It be the same type as the original (i.e., two-way, three-way, three-way plus air/three-way plus oxidation)
3. It be the proper model for the vehicle application as determined and specified by the manufacturer
4. It be properly connected to any existing air injection components on the vehicle
5. It be installed with any other required converter for a particular application
6. It be accompanied by a warranty information card to be completed by the installer.
Although some areas allow you to operate a vehicle without a catalytic converter for farm or off-road use... YOU CANNOT OPERATE THE VEHICLE ON PUBLIC ROADS.
	 Welcome Visitor! Please take a few seconds and
		 haha
 haha
