FAST Fabrication 94 b4000 turn into SNORE class 7 race truck build thread
Holy poo thats a lot of coin! Best of luck to ya! I sure hope you can win some of that back!
Temporary roof bar wires
Running lights
Inside lights that come on automatically, three warning lights are on because motor not on
Blue light behind mirror will be focused on switch panel when we mount it
Cab light on a switch, that lights up the panel for working on it
Shift light
Bumper euro lights
Bumper pencil
Roof lights
Valve for when its stored in the garage
Brake switch, we got an exhaust shield made and mounted, and have a rock shield made for the brake switch just not yet installed, need to do some tig work to it first
Gps is mounted and all wired up
The roof bar is completely wired now, and every light is working. If you look closely the wire on the v bar never actually touches the bar
Panel light is mounted
Horn Button & PTT mounted
Computer Support Bracket
Pumper and Intercom
Start of rear bumper, just need to fully weld and add the other two gussets
Still no luck on getting fuel level fixed, and on top of that we hit another snag. The tach shift light is no longer working, we cut the connector off so we could run the wires under the dash, and connected the wires back together and now not working. Tried switching the wires, I think the ground in the tach pulled out.
Do you have a light that you can shine on the co-driver and driver in the cab? They are great for harnessing up in the dark
good deal, they sound like nothing now but they are great when ya need them
Today we took break from truck and extended trailer, tomo while I’m getting the news stickers made there going to weld up the other ramp and cut and weld the covers for the extension
The Yukon bear got his jaw slapped out of him
Rear number plate
Roof number plate
Wishbone completed
Sway bar boots installed
Helmet arrived today
do you have earbuds for the intercom? Also what wattage is your in-car radio?
we didn't have earbuds and it sucked, I would recommend them
