Valve for when its stored in the garage
Brake switch, we got an exhaust shield made and mounted, and have a rock shield made for the brake switch just not yet installed, need to do some tig work to it first
Gps is mounted and all wired up
The roof bar is completely wired now, and every light is working. If you look closely the wire on the v bar never actually touches the bar
Panel light is mounted
Horn Button & PTT mounted
Computer Support Bracket
Pumper and Intercom
Start of rear bumper, just need to fully weld and add the other two gussets
Still no luck on getting fuel level fixed, and on top of that we hit another snag. The tach shift light is no longer working, we cut the connector off so we could run the wires under the dash, and connected the wires back together and now not working. Tried switching the wires, I think the ground in the tach pulled out.
