Has any one put a Dana 300 to an 4r55e trans!?!? If so I would love to know how??? Send a link anything helps
Thank and no I have a Dana 44 HP but I have the BW 1354 E T-case so It has a bowl cup design where you bolt the driveline up and with so much drop it will hit the trany x-member so I wanted to build a Dana 300 twin stick and clock it. Ause I have one already but I found out that there really is no kit to bolt on for a new t-case because I called advanced addaptors and they told me that the atlis is the only one that would work... So idk what I'm going to doI don't recall any kind of adapter made for that combo, for a fullsize transmission they do. Are you using a pass side diff that you need a right side front output on the t-case? If that's the case I don't know of really any right side output t-cases that would work let alone have an adapter. The only possibility I can think would be to find a divorced NP205 and put it behind your existing driveline,
Matt
