FAST Fabrication 94 b4000 turn into SNORE class 7 race truck build thread
Wow 8:30 pm and we just finished getting the center support bolted in, rear hangers welded on, and new H.A.D. driveshaft in. At full bump we have no binding what so ever. Exhaust tips clear wish bone, even though it wouldn’t of matter. After expo that is being removed and we are building our own wishbone.
Here are pictures of the spare tire setup, along with the new fuel filler mount, and our custom ratchet hold down. We are building the ratching part into the cage work and stitching our own straps that start as a single strap and split into a web/cradle setup to hold the tire down evenly.
Passenger side
Fuel filler
Strap Setup
Parts
The rear center support, we heavily modified the original one. This one bolts in and has adjustment, was put in place to where the driveshaft ended up at the correct angle. The rear hangers had to be flipped to the back side of the support. Got it all bolted up and put the driveshaft in at about 7:45 tonight.
Midship setup
Lot of scraping underneath, to get it clean
Driveshaft in
why did you go with a 2pc drivline?
unless you have a full tube truck with no floor and standard cab, then you really have no choice but to go 2 piece, because at full bump the one piece would hit the floor of the cab. our pivot point is at the center of both the upper and lower link pockets of rear suspension
Dash is complete minus the GPS which I will get later on, dash and console (mounted the starter button in console next to intercom) are ready for paint.
Didnt do much to truck, had to help brother get new transfer case in so he could get back up to san francisco
I have been working hard on the new graphics, had to make some compromises, but I am confident that it will be better then the previous one.
Thats a crapton of switches! Hope you have some labels in the works.
Here are updated pictures minus the new paint and graphics, if you look through them though you may find a sneak preview  mostly plumbing And electrical
Fuel, vent, and ground lines
its looking gorgeous, did you get behind the wheel for a bit?
