Rearanger
What CFM are you trying to get? Less CFM will give you less load but less airflow cooling - especially for A/C. Fan blade weight will surely reduce load but using this fan on an OEM clutch will not probably get much load reduction (given same CFM) since most of the weight is in the clutch, even though it's close(r) to the center of rotation. Is the flex fan designed to give constant CFM at variable RPMs?
