Not as many pics as I wanted, but that was because significantly more time was spent driving the trail this time around. The winter has really eroded out the trail and its getting pretty hairy in places. Much more technical now. There was tons of snow drifts close to the top, making the trail VERY challenging. Where my dad's jeep and his cousin's jeep did really well with their short wheelbases on the rocks, my long wheelbase worked wonders in the snow drifts. I was pulling my dad through some of the time because of it.
I aired down to 14 psi in the new KM2's. All I can say is holy wow. Major step up over the AT's. The sidewalls worked wonders, bit hard and never let me down. The tread deforms nice, and the lugs hook up consistantly. I got to use them on mud, snow, rocks (wet and dry), dirt, gravel and every kind of combination and shade between. Never once did they disappoint me
My newish radiator exploded right at the inlet on the plastic end tank at a very un-opportune place in the trail. So We pulled off, pulled it all apart, and put JB weld putty all on and around the break, tying it all off with bailing wire to keep it tight. I will get a pic later of it when I take it all back apart. Thanks for the JB Darrin!
Once we did that, we had lunch and let the JB set up. Then filled it with water, and kept a continual pile of snow in front of the radiator. I kept wheeling like this for the next 4 hrs, with not even a hint of overheating. I only added water once and the whole trip home and none was leaking. In fact it ran at normal temps for the rest of the trip on straight water. The key was to leave the radiator cap not all the way tightened down, so the pressure couldn't build up and blow out our JB-weld job.
Oh, and dad's new D44 is kick-butt. Solid, stable, and way beefier than before. D30's are boat anchors! His new highsteer setup performed flawlessly.
Fixed:
The view od Caples Lake:
