2WD 3 inch Suspension lift for CHEAP
Do you just need shocks with the spindle lift or is there any other parts? mines torsion
I'm not sure what's all included if you get a setup for the torsion bar suspension, but my truck is a coil spring setup, and it includes the spindles, shocks, etc. Check out what Jim has on his parts site.
Fox doesn't only make resi's, they also make hi-po aftermarket shocks too.
the point is you won't need hi performance shocks on a spindle lift because they do nothing to make your suspension to perform better
so pricing out camburg im looking at about 5000.
i may just go with something cheaper, though i havent decided. im running 32's on factory 2wd suspension though.
Are you running the 3.55 gears? If so how do they handle the 32? I want my next set of tires to be 33's but my wallet says it can't afford that and 4.10 gears haha.
Nice...you rubbing the inner fenderwells at all?
I would probably assume so, my 31's have the slightest rub with a good sized bumb.
ill put it nicely, its bad. with my auto, it has no power, and you cant punch it or you'll burn your tranny. its like im towing a 2000 lbs trailer behind me at all times.
i actually just bought a custom built 8.8 LS with 4.56 gears thats going in this weekend.
I wouldnt go higher then 31's if you dont plan on getting an axle. i get like 350 km in the city, though my highway mileage is awesome!
heres the truck before and so far.
