2011 ranger chip
bdowney
Hey, just wondering if there are any decent chips for the 2011 ranger that arent like 200 bucks. im not looking for anything special just something to squeeze every drop i can out of my new truck.
Chips, plenty. Good ones too.
Not for under $200. The cheap $50 jobbies are a scam.
scam look what it says it can do
The ACD Performance Module sends a modified signal through an engine data sensor, causing your factory Engine Control Module to reprogram itself for a more efficient air/fuel ratio and timing curve, essentially unlocking up to +75 Horsepower and up to +8 MPG in your vehicle!
Look at how they claim to do what they do.
Anything that says anything to this effect:
is a load of crap.
is a load of crap.
^^^What he said!!!!!
Might as well swap out that motor and get something better, Bro!!!! Just buy a programmable tuner. A bit more costly but they work better then any swap in chip!!!! I think they are around $340-400 for one. I do know that several shows on Power Block TV showed they worked.
Lmao ok i guess i should forget about those chips then...its just so tempting to try cause there cheap. Thanks for the heads up guys. Is there any in particular that u guys have worked with or own that u prefer?
Best to just Google it, Bro. Bully Dog, SCT for example has programble tuners but I not sure for the 2011 Ranger. I know they have them for up to 2010. You can look at their websites and see. Some are under $400. Check Summit Racing as well.
