Ranger 4x4 coils.
Coils & leafs are the same. Difference is the 2WD does not have a rear block, and the 2WD I-beam is shaped different.
Explorer leafs are heavier duty and will not bend as much thus giving you a little more lift and load capabilities but I have explorer springs in my ranger and they weren't any longer.
Explorers also use a spring-under-axle configuration. Because of this the leafs are arched a slight bit more as well.
I knew that, I'm just Lookin at some 4x4 coils. I have a 2wd extcab 2.3 and he has a 4x4 4.0 ext cab
I think it depends more on optioning, such as engine size and Supercab/Std cab.
A 4.0L Supercab truck w/AC will have heavier springs than a std cab 4-cyl, regardless of which one's 2WD and 4x4.
But the springs will still physically interchange however.
Shit...that's my supplier for my shop...I'll have to print them out at work and take a photo of them. Gives you all the springs ford ever used in the ranger/expo with bushing sizes/part #s, arch, lengths, etc.
I was told on BroncoII.org that 2wd ranger coils will give you maybe an inch or 1.5" over stock 4x4 coils. not sure if thats true or not. i might try it, since i have a 2wd ranger and my b2 in the garage now at the same time. ill let you all know how it works out.
