- Apr 19, 2011
I'm trying to replace an uncomfortable driver seat in my 2003 Ranger Edge, Standard Cab. I'm willing to pay a couple hundred for a nice racing seat, but I'm having a hard time finding brackets for the 03 Standard Cab.
Here's a link for Scat Procar seat brackets, and they only show as compatible up to 2001 for this size cab.
http://www.procarbyscat.com/Adapters.asp#FordTrucks
Also Corbeau only goes up to 2001
http://www.corbeau.com/service/seat_brackets/
I measured the brackets, and they were pretty odd shaped.
The inner side seemed about 3/4 inch shorter than the outer side, and even the position of the front bolts (both at an angle) were slightly (1/4 inch) different on each side on the angled plane. Looks like a rather un-generic layout... which may explain why the bracket isn't made.
Does anyone know of an aftermarket seat that has a bracket to match 2003 Edge Standard Cab?
Otherwise, I guess the thing that folks do is fit the original bracket to the new seat. So if I'm lucky, I can detach the slider off the original seats and bolt them (perhaps new holes will need to be drilled) to the new seat?
