- Aug 10, 2007
- Age
- 43
- Jonesboro, AR
Why not move the buckets forward?
i want to, but the "kickout" of the frame around the steering box makes that a little more difficult
great info on how to do a fw axle swap , also are you going to run fender flares and what size tires do you plan to run
thanks for the info , your thread makes it look alot easyer then i thought it would be to do a fw axle swap![]()
well, i was going to do some work to the F150 today, but didn't have some of the tools i thought i did.
so i worked on the BII instead!
Got the "new" 44 swapped in. i really miss that hoist, this would have been a lot easier if i still had it. someday i need to break down and buy my own. i was hoping my order from bronco graveyard would have come in, i ordered new "C" bushings, and some trans mount bushings (need them to start mocking up my trans mount). its been 8 days, so i checked and my order is "on hold". waiting for an answer from customer service....
while i had everything apart, i moved my radius arm brackets back, to try and straighten out those coils. i was only going to move them back 1.5", but there was a hole already about 2" forward that lined right up. that leaves 4 holes to drill instead of 6. since i had the hiems screwed all the way in, i backed them out .5". still plenty of thread left for fine tuning.
finally, i bolted on an old set of shocks in the front. not good enough for street use, but should help cut down on all the "bounce" when i'm lifting and moving stuff around.
so the front wont be pushed out as far as i would have liked, but at this point i just want to get it done.
oh yeah, managed to smack my hand with a hammer. pinched (and split open) a chunk between my thumb and first finger. right where your hand "grips". if i was left handed, i'd be pissed, haha.
they had a party there this weekend. sure they are busy busy busy
wondering if my bro broght home some sort of bronco for me to work on![]()
I was watching the video on the JBG homepage of their celebration, looked like a sweet time. i would love to be there
