Introduction
Here is a breakdown of the 2019-2023 Ford Ranger 2.3L EcoBoost Maintenance Schedule / Service Intervals and fluid recommendations.
Schedule / Intervals
| Service Procedure | Normal Service Interval | Special Service Interval | Notes |
| Replace engine air filter | 30,000 miles | N/A | Inspect frequently and replace as necessary |
| Replace engine oil & filter | As advised by Intelligent Oil-Life Monitor | 5,000 miles/6 months if operating in off-road conditions 3,000 miles if operating in extremely hot, desert climates |
Oil life monitor will typically account for driving behavior, but driver should be advised of special service conditions |
| Replace fuel filters | 30,000 miles | N/A | Engine and chassis mounted filters |
| Replace accessory drive belt | 150,000 miles | N/A | Inspect serpentine belt condition at oil change intervals and replace as necessary |
| Replace engine spark plugs | 100,000 miles | 60,000 miles | Special service interval applies to trucks that are towing or idling for excessive periods of time |
| Replace transmission fluid & filter | 150,000 miles | NA | N/A |
| Replace engine coolant | 100,000 miles/6 years for initial service, followed by subsequent service at 50,000 mile/3 year intervals | N/A | Use Motorcraft Orange engine coolant only |
| Replace rear axle fluid | 150,000 miles | N/A | Replace immediately if submerged in water |
| Replace front axle fluid | 150,000 miles | N/A | |
| Replace transfer case fluid | 150,000 miles | N/A |
Fluid Recommendations:
| Engine Oil | SAE 5W-30 Synthetic Blend | 6.2-Quarts with filter change |
| Engine Coolant | Motorcraft Orange Engine Coolant | 11.6-Quarts |
| Transmission Fluid | MERCON ULV Automatic Transmission Fluid | 12.8-Quarts |
| Transfer Case Fluid | MERCON LV Automatic Transmission Fluid | 1.2-Liters |
| Front Differential (M190) | Motorcraft SAE 80W90 | 1.64-Pints (0.775-Liters) |
| Rear Differential (M220) | Motorcraft SAE 80W90 | 3.70-Pints (1.75-Liters) |
| Rear Differential With Electric Locker (M220) | Motorcraft SAE 80W90 | 3.04-Pints (1.44-Liters) |
| Brake Fluid | DOT 4 |
About The Author
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford Ranger off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
