Rear Leaf Spring Specs:
The chart below lists the leaf spring specs for the Ford Explorer, Ranger, Bronco, and Bronco II.
Leaf Spring Eye Bolts:
9/16″ Grade 8
  • The 1991-2002 Ford Explorer and Explorer Sport uses 9/16″ x 4-1/2″ Grade 8 bolts in the front and rear hanger
  • The 2003-2006 Ford Explorer Sport Trac uses 9/16″ x 4-1/2″ Grade 8 bolts in the rear hanger
  • The 1986-2003 Ford Ranger uses 9/16″ x 4-1/2″ Grade 8 bolts in the front and rear hanger
  • The 2004-2011 Ford Ranger uses 9/16″ x 4-1/2″ Grade 8 bolts in the rear hanger
  • The 1983-1985 Ford Ranger uses 9/16″ x 4-1/2″ Grade 8 bolts in the front hanger
  • The 1984-1990 Ford Bronco II uses 9/16″ x 4-1/2″ Grade 8 bolts in the front and rear hanger
  • The 1978-1996 Ford Bronco uses 9/16″ x 5″ Grade 8 bolts in the rear spring hanger
5/8″ Grade 8
  • The 2003-2006 Ford Explorer Sport Trac uses 5/8″ x  4-1/2″ Grade 8 bolts in the front spring hanger
  • The 1983-1985 Ford Ranger uses 5/8″ x 4-1/2″ Grade 8 bolts in the rear spring hanger
  • The 2004-2011 Ford Ranger uses 5/8″ x 4-1/2″ Grade 8 bolts in the front spring hanger
  • The 1978-1986 Ford Bronco uses 5/8″ x 5″ Grade 8 bolts in the front spring hanger
Ford Explorer
Ford Part #
Description
1991-2001 Explorer 4DR (2wd & 4wd)
1991-2002 Explorer Sport (2wd &  4wd)
Rear Code U
F1TZ5560A
F17A5560DC
2-1/2″ (W) x 25-11/16″ (S.E) x 30-15/16″ (L.E),  3/1, (4-Leafs)
Grading,  3/.360 1/.590,  Pack Thickness (1-7/8″)
(1,250 Lbs) Capacity Each Rear Leaf Spring, Arch  (4-13/16″)
Uses 9/16″ x 4 1/2″ Grade 8 Leaf Spring Eye Bolt Front and Rear
1995-2001 Explorer 4DR (2wd & 4wd)
Includes Mazda Navajo 2wd & 4wd
1997-2001 Mercury Mountaineer 2DR & 4DR (2wd & 4wd)
Rear Code F
F57Z5560A
F57A5560FD
2-1/2″ (W) x 25-11/16″ (S.E) x 30-15/16″ (L.E),  3/1 (4-Leafs)
Grading, 2/.323, 1/.307, 1/.590,  Pack Thickness (1-3/4″)
(1,100 Lbs) Capacity Each Rear Leaf Spring,  Arch (6-1/2″)
Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolt Front and Rear
2001-2002 Explorer Sport Trac (2wd & 4wd)
1L5Z5560BA
1L545560BC
2-1/2″ (W) x 25-3/4″ (S.E) x 31″ (L.E),  3/1,(4-Leafs)
Grading,  1/.341,  1/.307,  1/.291,  1/.590
(1200 Lbs) Capacity Each Rear Leaf Spring
Pack Thickness  (1-15/16″),  Arch  (8″)
Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolts Front and Rear
2003-2006 Explorer Sport Trac (2wd & 4wd)
4L2Z5560AA
4L245560BA
2-1/2″ (W) x 25-3/4″ (S.E) x 31″ (L.E), 3/1, (4-Leafs)
Grading,  1Lv @.341,  1Lv @.307,  1Lv @.291,  1Lv @.590
Uses 5/8″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolts Front
Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolts Rear
Ford Part #
Description
1986-2003 Ranger (2wd & 4wd)
E3TZ5560G
E2TA5560CA
2-1/2″ (W) x 25-5/8″ (S.E) x  31″ (L.E),  3/1 (4-Leaf)
Grading,  2Lvs @.307,  1Lv @.291,  1Lv @.558
Pack Thickness  (1-1/2″), Arch  (6″)
Front and Rear Leaf Spring Eye Bushings Included
Uses 9/16″ x 4 1/2″ Grade 8  Leaf Spring Eye Bolts Front & Rear
1983-1985 Ranger (2wd & 4wd)
E4TZ-5560C
E47A-5560UA9
2-1/2″ (W) x 25-5/8″ (S.E) x 31″ (L.E), 3/1,(4-Leafs)
Grading,  3/.323, 1/.590,  Pack Thickness  (1-9/16″)
(1,350 Lbs) Capacity Each Rear Leaf Spring,  Arch  (4-5/8″)
Uses 5/8″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolt Rear
E6TZ5560M
E67A5560UB
2-1/2″ (W) x 25-5/8″ (S.E) x 31″ (L.E), 3/1 (4-Leafs)
Pack Thickness  (1-9/16″),  Arch (4-3/8″)
Grading,  3Lvs @.291,   1Lv @.662
(1350 Lbs) Capacity Each Rear Leaf Spring
Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolts Front & Rear
F37Z5560A
F37A5560BB
2-1/2″ (W) x 25-11/16″ (S.E) x 30-15/16″ (L.E)  2/1 (3-Leafs)
Grading,  1/.323, 1/.341, 1/558
Pack Thickness  (1-3/8″), Arch (6-13/16″)
(1,110 Lbs) Capacity Each Rear Leaf Spring
2004-2011 Ranger (2wd & 4wd)
4L5Z5560EB
4L545560EB
2-1/2″ (W) x 25 3/4″ (S.E) x  31″ (L.E),  3/1 (4-Leafs)
Grading,  1Lv @.307,  2Lvs @.291,  1Lv @.558
Pack Thickness  (1-11/16″)
(1,200 Lbs) Capacity Each Rear Leaf Spring,  Arch  (6-1/8″)
Uses 5/8″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolt Front Eyes
Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolt Rear Eyes
Ford Bronco, Bronco II
Ford Part #
Description
1978-1979 Bronco – Full Size
D8TZ5560B
D8TA5560DB
3″ (W) x 24″ (S.E) x 31-1/2″ (L.E),  4/1, (5-Leafs)
Grading, 2/.291, 2/.262, 1/’625,  Pack Thickness, (1.78″)
(1,650 Lbs) Capacity Each Rear Leaf Spring,  Arch  (7-3/4″)
Uses 5/8″ x 5″ Grade 8 Leaf Spring Eye Bolt Front Eyes
Uses 9/16″ x 5″ Grade 8 Leaf Spring Eye Bolt Rear Eyes
1980-1996 Bronco – Full Size
EOTZ5560AD
EOTA5560AZC
3″ (W) x 25″ (S.E) x 31″ (L.E),  4/1 (5-Leafs)
Grading,  2/.307, 2/.291, 1/.625
Arch (6-5/8″),  Pack Thickness  (1-7/8″)
1984-1990 Bronco II (2wd & 4wd)
E6TZ5560F
E67A5560JA
2-1/2″ (W) x 25-3/4″ (S.E) x 30-7/8″ (L.E),  (5-Leafs)
Grading,  1Lv @.323, 1Lv @.262,   3Lvs @.249
Pack Thickness  (1-3/8″), Arch  (6-5/8″)
(1,020 Lbs) Capacity Each Rear Leaf Spring
Looking for stock or heavy duty replacement leaf springs? Check out ATS Springs.
About The Author
