2001 Ranger 4.0 Problems
Galena
MO - USA
2001 Ranger
Drive
Hi folks. This is my first post, sorta. Computer took a dump and destroyed all my passwords and user names so I rejoined.
I've got a problem with my 2001 Ford Ranger XLT 4.0 engine. Runs fine in cooler weather but on a hot day the engine starts to shut down., no acceleration. If I pull off the road, turn the engine off for a few minutes then restart it all is good; for 5 miles or so. Then it starts all over, surging and loss of power. The idle is not affected. Just when I try to accelerate.
Put a code reader on it and no codes. Thought it might be the fuel filter, changed that out, installed a new MAF sensor on and that didn't fix it.
Have any of guys ever ran across a problem like this? Again, just on hot days. If the outside temp is 60F or below, engine runs like a dream.
Is it possible this could be a fuel pump going bad? Possible that the warmer days affect the pump in some way? This problem showed up late last summer, then it cooled down. All winter truck ran fine. Now with the return of warm weather the problem's back.
Thanks in advance. Any help you can give me is much appreciated! Zack
On an 01, do you have a scanner that can view live data?
If so the first thing I'd check is engine temperature when it does it. This feels like the computer thinks it's hotter than it really is...
Thanks SenorNoob, I'll check it out. YES, I do have a scanner that can view live data. Bought one for this project.
I've been reading about Ford's 'limp mode'. Was limp mode a thing back in 2001? When did they start doing that? Thanks for your reply. Zack
Yeah, I’d take a good look at live data. Before, during and after it does it. Something is reacting badly to heat. On the old trucks that was usually the TFI module but that doesn’t apply to you exactly. The 4.0 never used those.
Limp mode has been a thing on EFI since at least the late 80s. Always gotta have some kind of plan if a sensor goes out.
Well, I think I'm getting somewhere. That live stream code reader is SO much better than what I had/have. There is a learning curve to it.
55F here so of course the Ranger motor runs like a dream. The problem waits till hot weather to rear its ugly head.
BUT, I did drive it to town today, ran it hard and, when I got home and before I shut the motor off I plugged in the new live stream code reader and it showed a 'pending' P0455 code, which says:
Evaporative Emission Control System Leak Detected (gross leak).
What'll happen I think, is that after the motor cools down the pending P0455 code will go away. What goes bad on the EVAP system that might be causing this problem? Any insight is surely appreciated. Zack
PS, SenorNoob, that makes sense, EVAP system had a bad gross leak and is going into 'limp' mode to protect the engine. The hotter the ambient air temp the more pronounced the problem, finally getting drastic enough that the computer limits the rpm to protect the engine. Does that sound right to you?
So, that can be a broken vacuum line, or a bad EVAP line. The weird thing is that my one 00 Ranger never showed an issue or EVAP code, but when I ripped it apart to do a 5.0 swap, the main EVAP line was rotted to garbage. I’m talking holes in the line. Big ones. Computer said all fine. I replanted line with aluminum tube, no more rot.
Thanks for the reply BlueFord. EVAP system definitely needs some attention but I don't know if that's what's shutting down the truck on hot days. Did a web search on P0455 and looks to me like that problem is not severe enough to cause the computer to drop the motor RPMs.
I'm getting tired of fooling with it.
Got an appointment Monday to get it in to a local mechanic I trust. Let him play with it. I've got my trusty ol' 94 Toyota pickup for a spare to drive till it's fixed. Got some warm days coming up next week also. That's when the truck engine does it's tricks. I'll post what he found. Might help someone else that has had this problem. Zack
You are correct, that’s not usually enough to be a huge problem, pretty sure there’s something else going on.
Honestly, without the vehicle in front of someone or more diagnostic it’s hard to say. There’s a decent amount of sensors and stuff that can act up and cause problems and unfortunately with parts quality being what it is these days, just firing the ol parts cannon doesn’t mean you may resolve the problem. I have a 180* “premium” thermostat that opens at 165* sitting in my parts collection. Starting to seem like once you install a new part or before you install it, that you need to test it to make sure it does what it’s supposed to out of the box. Makes troubleshooting a problem a headache sometimes.
Hey at least it opened. LOL.
I got 2 spark plugs yesterday for the fourwheeler. (It's a single I just wanted an extra in case I drowned one.) Neither one works. How the @#$$ do you $#% up 2 new identical NGK spark plugs? No it's not the ignition. Same part number as the old one and it works fine despite having been drowned on multiple occasions.
Well, just talked to the mechanic a while ago......Fuel pump. Has a warm day with 85F. He took it out on the road and it tried to quit on him. Said he barely got it back to his shop. Said it wasn't normal for a fuel pump to act like that, that they usually either work or they don't. Problems late last summer that went away with the cold weather and then came back with the warm weather this year.
Some electric component in there that is affected by heat obviously.
Anyway, just glad it's getting fixed and glad I don't have to change it myself. Zack
Just got my Ranger back. Runs great! And, I didn't have to drop the fuel tank or take the bed off myself. Money well spent!
Where did you buy the plugs? There are counterfeit ngks all over eBay and Amazon.
Oreilly's
Not the first time I've had problems with NGK plugs there. Wondering if maybe they got some of those counterfeit ones?
