Differential Draining and Filling
Materials:
Motorcraft SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL
Vehicles:
2019-2010 Ford Ranger
Draining:
1. With the vehicle in NEUTRAL, position it on a hoist. Refer to: Jacking and Lifting (100-02 Jacking and Lifting, Description and Operation).
2. Remove and discard the differential oil fill plug.
3. NOTE: Be prepared to collect escaping fluids. Remove and discard the differential oil drain plug.
4. NOTE: Make sure that a new component is installed. Install the differential oil drain plug. Torque: 20 lb.ft (27 Nm)
Filling
1. Fill the differential with clean differential gear lubricant. Motorcraft® SAE 80W-90 Premium Rear Axle Lubricant / XY-80W90-QL (WSP-M2C197-A)
2. Check the differential fluid level. The differential gear lubricant level should be to the bottom of fluid fill plug opening.
3. NOTE: Make sure that a new component is installed. Install the differential fluid fill plug. Torque: 20 lb.ft (27 Nm)
About The Author
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford Ranger off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
