Removal:
NOTICE: Suspension fasteners are critical parts that affect the performance of vital components and systems. Failure of these fasteners may result in major service expense. Use the same or equivalent parts if replacement is necessary. Do not use a replacement part of lesser quality or substitute design. Tighten fasteners as specified.
1. Remove the front wheel speed sensor.
2. Remove the brake disc. Removal
2. Remove the brake disc. Refer to: Brake Disc (206-03 Front Disc Brake, Removal and Installation).
3. Remove and discard the wheel hub nut.
4. Remove and discard the 4 front wheel bearing and wheel hub bolts. Remove the front wheel bearing and wheel hub.
Installation:
1. NOTICE: Install and tighten the new wheel hub nut to specification in a continuous rotation. Always install a new wheel hub nut after loosening or when not tightened to specification in a continuous rotation or damage to the components may occur.
NOTICE: If the original wheel bearing and wheel hub is being installed, install a new wheel hub O-ring seal or damage to the wheel bearing may occur.
NOTE: Tighten the bolts in a cross pattern.
Position the front wheel bearing and wheel hub and install the 4 new front wheel bearing and wheel hub bolts.
Torque: 129 lb.ft (175 Nm)
2. NOTE: Apply the brake to keep the halfshaft from rotating. While an assistant applies the brake, install the new wheel hub nut.
Torque: 221 lb.ft (300 Nm)
3. Install the disc brake.
4. Install the front wheel speed sensor. Torque: 53 lb.in (6 Nm)
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford Ranger off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
