The 2019 Ford Ranger returned to the North American market with Spicer (Dana) AdvanTek axles. Gone is the Ford 8.8-Inch rear axle that we knew for so long.
Spicer® AdvanTEK® high-efficiency axles deliver more miles per gallon, enhanced vehicle performance, and maximum durability for the complete spectrum of light vehicles. Even with its compact design, these axles provide greater power density than similar offerings while reducing driveline weight with lighter, higher strength materials and advanced gearing. Spicer AdvanTEK axles make it possible for vehicles to handle today’s high-torque engines.
Vehicles:
2019-2020 Ford Ranger
Standard Features:
Pinion features to enhance reliability:
  • Larger diameter pinion stem
  • Narrow pinion bearing spread
  • Two-stage pinion preload setting
  • Pinion mate spherical torus shape
Pinion features that reduce vibration:
  • Pinion built to position rather than pattern
  • Major diameter pinion spline fit
  • Reduced pinion nut backface runout
Gearing features to improve durability:
  • Wider drive gear face
  • Differential gear tooth combination
  • Large diameter flange side differential bearing
Gearing features that maximize efficiency:
  • Fuel efficient taper roller bearing
  • Smaller button side differential bearing
Thrust washer features for a quieter ride:
  • Dynamic backlash measurement
  • Belleville side gear thrust washers
  • Thrust washer lubrication holes
Ford Ranger Front Axle:
The 2019 Ford Ranger uses The Dana Advantek 190 mm (M190) axle in the independent front suspension:
The 190 mm axle measures out to 7.48 inches.
Ford Ranger Rear Axle:
The 2019 Ford Ranger uses the Dana Advantek 220 mm (M220) Salisbury beam axle in the rear:
The 220 mm measures out to 8.66 inches.
This axle is available with or without an electric locker.
Also Check Out:
Dana Spicer Advantek Axles In Your Ranger
Dana M220 Rear Axle Fluid Change Instructions
Dana M220 Rear Axle Fluid Check
Dana M190 Front Axle Fluid Change Instructions
Dana M190 Front Wheel Hub Bearing Removal & Installation
Website |  + posts
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford Ranger off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
