Getting my 1996 Ford Ranger ready to pass a state emission inspection, I had to diagnose Ford trouble codes P0155 and P1151.
P0155 O2 Sensor Heater Circuit Bank 2 Sensor 1
What are the common causes of code P0155?​
  • Problem on the ground side of the O2 sensor heater circuit​
  • Problem on the power side of the O2 sensor heater circuit​
  • O2 sensor heater element has high resistance​
  • O2 sensor heater element has an open circuit​
P1151 Lock of HO2S21 Switch – Sensor Indicates Lean
P1151 FORD Possible Causes​
  • Faulty Upstream Oxygen Sensor Bank 2 (P0155 above?)​
  • Fuel pressure high or low​
  • MAF sensor dirty/defective​
  • Vacuum leak on engine​
  • Leaking fuel injector or fuel pressure regulator​
  • Faulty Powertrain Control Module (PCM)​
O2 Sensor Bank Locations:
The trouble code indicated that the bad O2 sensor was in Bank 2 Sensor 1 which placed it on the drivers side.
Making The Repair:
Replacing an O2 sensor is a cheap and simple process. The O2 sensor takes a 22mm or 7/8-inch wrench. I actually had a 7/8-inch line wrench that worked perfectly. Some people use a regular wrench and just slide it over the plug, or cut the plug off since the new O2 sensor comes with a plug.
Your new O2 sensor should have some anti-seize on the threads. If not, make sure you add some.
Although the exhaust and O2 sensor was rusty looking, I was surprised at how easy it came out.
Here’s the new O2 sensor in after adding a dab of anti-seize to the threads.
It’s Fixed!
After replacing the O2 sensor and clearing the codes, I took the Ranger for a test drive and the code didn’t come back.
About The Author
