General Specifications (at curb weight)
NOTE: Measurements listed at curb load. Curb load is defined as “full service fluids, full fuel tank(s), no passengers and no cargo”.
Item Specification
Ball Joint Deflection
Upper 0-0.2 mm (0-0.008 in)
Lower 0-0.8 mm (0-0.032 in)
Front Ride Height (All Vehicles)
4WD 111 mm ± 12 mm
RWD 93.5 mm ± 12 mm
Rear Ride Height (All Vehicles)
4WD / RWD 319 mm ± 12 mm
Side-to-Side Variation (All Vehicles)
Front ± 8 mm
Rear ± 8 mm
Alignment Specifications (at curb weight) 4WD – vehicles Super Cab/ Crew Cab
Item Left Right Tolerance (side to side)
Camber Front 0.03° ± 0.75° 0.03° ± 0.75° 0.00° ± 0.75°
Camber Rear
Caster Front 2.72° ± 0.75° 2.72° ± 0.75° 0.00° ± 0.75°
Caster Front – Bridgestone 255/70R16 and 265/60R18 2.47° ± 0.75° 2.97° ± 0.75° -0.50° ± 0.75°
Caster Rear
Toe @ curb ride height (positive value is toe in, negative value is toe out) 0.00° ± 0.10° 0.00° ± 0.10° 0.00° ± 0.20°
Thrust Angle 0.00° ± 0.50°
Alignment Specifications (at curb weight) RWD – vehicles Super Cab/ Crew Cab
Camber Front -0.44° ± 0.75° -0.44° ± 0.75° 0.00° ± 0.75°
Camber Rear
Caster Front 2.90° ± 0.75° 2.90° ± 0.75° 0.00° ± 0.75°
Caster Front – Bridgestone 255/70R16 and 265/60R18 2.65° ± 0.75° 3.15° ± 0.75° -0.50° ± 0.75°
Caster Rear
Website |  + posts
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford Ranger off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
