mixwell
- Jan 2, 2009
- Reaction score
- 1
- Location
- Los Angeles, CA
- Make / Model
- Ford
- Automatic
Well I did a compression check and I'm showing Cylinder's 1 and 2 are low. While the others average about 150, cylinder 2 is @ 120 and cylinder 1 is @ about 75 !! I have the Hayne's manual and it is suggesting that a worn came lobe could be an issue if 1 cylinder is below 20% of the others.
I have also read that when 2 cylinders next to each other are low it could indicate a blown head gasket. I plan on having some help to remove the head tomorrow but I was going to take it to a shop to get a head job done since if I have to replace the gasket might as well get it all done legit. Anyone have similar issues ? Any insight is appreciated. Thanks in advance !!
By the way its a v6 3.0 (2001 Ranger)
-- MixweLL
-- MixweLL
