fuel filter location
86ranger4x4owner
2.9l
Can anyone tell me the exact location of a fuel filter on a 1986 2.3l ranger 4x4
86ranger4x4owner
2.9l
So no one knows where the fuel filter is on a 86 2.3l 4x4 ranger?
86ranger4x4owner
2.9l
And another question can i use a regular round tire pressure gauge to check the fuel pressure? or do i have to have a gas pressure guage?
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Inside the driver framerail, located under the door, before the framerail bends up to the coil bucket...As far as checking pressure, I would use a special gauge for that...
SVT
86ranger4x4owner
2.9l
SVT
ok i got two things in the frame rail under the door both have metal brackets one has wire and the other doesnt the one that doesnt have wire is right beside the transfer case with 3 bolts.and what the name of the tool i need to use?
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
One will be vertical (don't mess with this one), and the other is horizontal and closer to the front, this is the filter, one side (I believe the side coming from the tank) will have a small clip, just remove the clip and pull the fuel line off, the other side you will need a fuel line disconnect tool...
SVT
86ranger4x4owner
2.9l
SVT
the one at near the front has wires going to it though.
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Thats going to be your second fuel pump, your filter should be between that and the motor, look just in front of the pump, this is where the filter should be...
SVT
pbilt
ford
1988 2.3
the one that the last guy told you not to touch is the fuel filter its a canister filter the bottom unscrews and you just replace it i have a 85 same set up
Flat Toy
13
Dallas
2.9/2.5
This may or may not be the filter.
Look forward of this you will see the high pressure fuel pump. Follow the line out of the pump forward and if there is no filter by the time you you get to the engine you have the canister filter shown in the picture. Use a strap wrench to turn it off.
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
If this is the style filter you have, be cautious when re-installing the cover, do not get the O-ring pinched (it helps to lubricate it) as it will leak. At the time I had my B2 I unscrewed only to find mine had no filter inside, so I didn't know exactly what it was at the time...
SVT
86ranger4x4owner
2.9l
SVT
thats what it looks like i havent tryed looking in front of the other fuel pump and the one you showed me a pic of whats the name of it so i can find one at the parts store
Irokranger93
Michigan
3.0L
fuel filter..... really easy to say
Flat Toy
13
Dallas
2.9/2.5
This filter is most commonly known as a canister filter, if you have the one forward of the pump it would be a inline filter. Over the years I have seen several different set up's. Some with only the canister, some with just the inline with no filter in the housing pictured above, some without the canister housing at all. One I saw had a inline filter and a canister filter. At this age its hard to tell what people have done to the fuel systems over the years. As far as the 86 I think they came from the factory with just the canister with a filter in it. I could be wrong but that is what I have seen the most of on the 86.
86ranger4x4owner
2.9l
ok i found it on the parts store website i was just overlooking it and i dont think i have to replace it because am getting a good 40psi of pressure at the rail.
Similar threads
Staff online
Truck of The Year
Kirby N.
2024 Truck of The Year!
