zhillz
- Jan 19, 2012
- Automatic
Reserved.
Tons of pics and info coming.
Tired and sick of trying to find info? lemme help.
2002 Ford Ranger Supercab 4x4
SAS with Dana 44 and Ford 9" using leafs.
Goal is 36-38" tires depending on how she sits.
Project price goal without rim/tires = $3000
Dana 44 with disk brakes, tie rod, "custom highsteering" passenger side knuckle 5.13 gears trutrack locker, chromoly axles set up for CJ leafs
Ford 9" 5.13 gears 31 spline with full spool still with drums set up for CJ
Bronco II what are supposed to be 8" lift rear leafs with shackles and bushings= $150
YJ Front 4" leafs 287lbs 2.5" wide $78 each plus $20 for bushings and $8 each shipping charge or "extra" size item =$114 ea
9" perches 3.25" axle tubing 7" anti-wrap= $40
Dana 44 perches 2.75 axle tubing 7" anti-wrap=$40
Ford 9" 3.25" axle tube U bolt kit with spring plates = $45 shipped
I need to measure the front tubes because the only u-bolt/plate "kit" for the d44 I can find is $80 + shipping because of ubolt being different? which is insane.
Toyota '93 steering box with pitman arm $60 off craigslist.
