FourPointOh
Bought around March '11 had 111k miles, XLT.
As it is now, 119k.
had some bad luck with some black ice and a ditch
Have since cranked the torsion bars ~1.25"
Old exhaust was hung up by coat hangers from the previous owner, so I got a flowmaster super 44 and magnaflow tailpipe.
I had made a sound clip but it was to distorted, will have to remake one. Also i want to replace the midpipe as well since its still the stock one.
12" 4-ohm subwoofer
polypropylene cone with foam surround
power range: 100-300 watts RMS
peak power handling: 600 watts
frequency response: 22-250 Hz
sensitivity: 85.64 dB
sealed enclosure for one 12" subwoofer
5/8" MDF (medium-density fiberboard) with gray carpet covering
internal volume: 1.3 cubic feet
nickel-plate binding post terminals
got the box for 25 dollars, otherwise i probably would've just built my own
RMS Power Output 20 wattsx4
Peak Output 50 wattsx4
RMS Power Bandwidth 20-20kHz
Preamp Outputs 2-channel
Sub Preamp Outputs No
Switchable Rear Preamp Outputs Yes
Preamp Voltage 2.5 volts
I also would like to get a new radio deck
320watt rms
bass boost, may upgrade to a bigger amp later on
this should be here tuesday, I know not everyone is big on aftermarket intakes though
As it is now, 119k.
12" 4-ohm subwoofer
320watt rms
