HoleshotKFX400
Got everything wired up i believe but i cant turn the motor over with the key, i think its the clutch switch that only lets you start it with the clutch depressed. How do i jump this, and where is the switch... I believe its under the dash on the clutch pedel right? but what two wires do i have to jump together??? is it pink and red/lt blue... It turns over if i jump the solenoid with a screw driver, just not with the key... thanks for your help again
