91rangeryder
Hi TRS members I've got an idle and overall performance issue with my truck I've searched threads and have found similar problems but none of their fixes helped me. Truck starts runs decent but at operating temperature it Idles at around 1100 to 1200 in park and no less than 1000 in drive when you rev the motor let’s say to3k it doesn’t idle down right away it will drop to 2.5k then 1.5 then about 1.2 in about 3 to 5 second increments. When driving it the motor seems hesitant throughout the throttle range. This is my first 4.0 and fith ranger and it seems as slow as some 2.3s and 3.0s I've had
Parts replaced/checked in order of test or replacement
O2 sensors: replaced both due to failed emissions test. after replacement passed retest with flying colors
EGR checked and is functioning
Checked for vacuum leaks everywhere
Cleaned MAF with sensor safe cleaner
IAC checked operation valve is working properly
TPS replaced/ with a new unit "replaced because had a spare new one"
Replaced All intake & exhaust manifold gaskets including upper and lower fuel rail and valve covers
Any Ideas or suggestions would be very appreciative or if I missed a post covering this let me know thanks !
