Ranger Rod
I'm back,,, been a couple years since I completed the rebuild with the help of the folks here and she is still running strong! I have however needed to replace exhaust components on the 1995 3.0 litre. Once coming to the Y pipe and cat connection it has been discovered there is much more rot than can be sealed, the problem being a Y pipe is not available from auto supply shops. This connection is not a standard circular fitting but kinda oval so the lip findings you can buy for a cut off and bolt on application will not suffice, any suggestions???
