Mystralhawk
- Nov 28, 2011
- Automatic
Hey guys,
I've been a lurker on here for quite a while. I've hit an issue with the Y pipe on my 2002 3.0 V6 Ranger. I've searched and searched, but haven't really found a solution.
The story:
I had to replace my rear main seal and took off my Y pipe.
I got everything back but when I started the truck back up, I had an exhaust leak where the Y pipe meets the manifold.
I thought the studs were fubared so I ended up cutting them off and using hush studfix brackets (for more info www.the-hush.com). Sadly my problem got even worse. Now the exhaust leak is even worse and the engine throws a code. I have not yet checked the code, but everything is bolted on tight.
Am I missing some sort of gasket/sealant between the Y pipe and the manifolds? The truck has been a non stop problem for 2 months now and I'd really like to get this resolved.
Thanks for everyone's help in advance. I look forward to hearing from everyone.
The story:
