dirtyhorse
- Jan 28, 2013
So I bought a 87 b2 for 300 engine runs amazing but needed a tranny replacement used one came with it turns out tail housing is 2.5 inches longer than the original with leads me to believe it cam from a extended cab ranger but it mounted up just fine with a shortened drive shaft but once I got it all buttoned up it grumbled in neutral and all gears I also lost all my clutch fluid after about 10 blocks could this groaning and loss of clutch fluid be from a bad slave cylinder possibly also I put 85-90w in the tranny is it ok to run in it I've been told it's fine to use in it could use some hints and tips on this tranny issue please
