- Jun 30, 2012
- Couer d'Alene ID
- Manual
I have a 1983 Ford Ranger 4wd with a 2.8l v6, 2 barrel carburetor, and 4 speed manual transmission.
I got the truck from a 90 year old man who bought it used in 1998 and had some work done over the next couple years. In 1999 he had the Carburetor overhauled with a new fuel filter and air filter. the rear differential was serviced as well as a 22 point service check that noted -
"antifreeze -35
removal drips
tamper seal plugs"
I have yet to decipher the previous notes.
He had the starter, spark plugs, cap, rotor and wires replaced in 2000.
Since October 2011 I replaced (in order) the fuel pump, master and slave clutch cylinders as well as the hydraulic line.
From May 2012 on I put in a new clutch kit with the pivot bearing and resurfaced the flywheel, a new u-joint on the rear front drive line and bought both u-joints for the front drive line but haven't installed it yet.
I dumped all of the stale gas out of the tank and blew air through the line from the tank to the pump and from the pump to the filter as well as took the filter off and blew through it. after all this the pump I replaced last October went bad and I warranty replaced it . I then refilled the tank with middle grade fuel and seafoam as well as stp brand octane booster and gas treatment. I topped off the power steering fluid and I did an oil change and replaced the filter. I also replaced the muffler and the rest of the exhaust is original as it is pretty much solid rust.
I still have the receipts from the previous owner and found one from 2000 that shows a "possible blown head gasket or cracked head. #1 cylinder has antifreeze leaking into it". This is the same receipt for the wires, cap, rotor and plugs. That worries me cause the truck runs great for the first few miles, then slowly the sound gets from bad to worse. I had the guy who resurfaced the flywheel listen to it idle in neutral after a 10 mile drive and he noticed "valve noise", but said the engine sounds normal otherwise. It seem like on the longer trips I take, the truck looses power. I also recently loaded up the bed and a trailer with 3 round trips at ten miles per round trip weighing between 500 to 800 pounds per load. after emptying the bed and unhooking the trailer, it sounds almost as bad as if I never replaced the muffler. I don't know what steps to take next. Can anyone offer advise?
"antifreeze -35
removal drips
tamper seal plugs"
