- Apr 13, 2008
- Bellefontaine, Ohio
- Automatic
Stripping my Baby: heres the front before, after i remove the turn signals.
The rear before, after i removed the taillights, cover for body lift and tailgate.
from the side.
starting to remove rear window, removed inner panels.
top.
outside before.
started witha small screw driver.
then a went to a bigger one.
the used a third down further.
started to pry out.
almost half out.
half out.
pushed out once i made my way down to the end with screw driver.
resting against roll bar.
once outside i pulled up.
pulled up.
done.
pulled the rollbar and bedmat and rear window.
pulled the grill, driving lights, grillguard, head lights and pulled up TRS sticker
as well as some engine parts.
everthing off exept driveshafts and wheels and tires.
found this at junkyard while lookin for junk wheels and tires rear coilovers on a first gen.
nice tire to bad i'm going to throw away.
everthing done exept drive shaft.
the saddest pic i've ever seen.
off to the crusher...
from the side.
top.
outside before.
started to pry out.
almost half out.
half out.
pulled up.
done.
