Fordtoughranger
- Nov 8, 2007
So I am planning on replacing my pushrods as I have excessive valve train noise and they appear to be the commonly worn part on the 4.0L OHV. Question I have is could worn out push rods cause the cold start to act as if the valves aren't opening completely in a few cyl. causing it to crank over hesitantly and then idle rough? Or would this symtom be more of a lifter bleeding off after sitting for a long time?
I have searched the forum and could find anyone with this same situation, just noisy pushrods.
Also searched for OEM pushrod length and couldn't find it. Napa Autoparts lists 3 different lengths at 5.42"/5.45"/and 5.48", so not sure which one to look for.
Thanks
Thanks
