dave 85
my 1985 2.3 5spd wont start ,but it will fire with starting fluid , the fuel pressure is in spec,i have replaced the Ecc and checked the ignition control module .
Thanks for the advice ! , now i am looking for the problem in the engine harness. would you know if there's anything on the engine sending unit etc that could turn off the injectors?Check that if the fuel pump is working the computer should be getting power. Are the injectors firing have someone crank on the starter while you listen to the injectors. Use the poor mans stethescope put a long screwdriver on an injector and put your ear up to the handle you should hear the clicking. Be careful of moving parts you can listen to bearings also alternater, power steering pump. Have you cleaned all the connector in the engine bay.
