wont start after clutch master install "HELP"
BLB4000
I took the clutch master cylinder off and bench bled it.
Put it back together and have a great pedal now but truck wont start.
It turns over but wont start.
95 Mazda B4000 4.0.
Any ideas ?
I got it.
Fuel pump was't powering up.
Found fuel schrader valve, released some pressure from it.
Got in turned key, fuel pump powered up, then it started.
I have no clue why it did this.
Any ideas ?
did u disconnect any wiring harness just to get them out of the way??? like the MAF or TPS. doing the master cylinder (i dont believe) would effect the ignition. just try to re-check all the connectors
__________________
Autopartswarehouse :3gears:
No, that's what baffles me.
I just released some pressure from the schrader valve, then it started up.
