Tgeddes
Help Needed
Bought 1988 Bronco ii with a bad engine knock. Pulled engine, installed a remanufactured block. Had a crank no start for a while even when using ether, had fuel and spark. Tore down and rebuilt double checking valves and timing chain. Dialed in timing with a light and got a little whisper of a cough when using ether but still no start.
Over the past year during this project, every time it sat for a day or so and I would go to give it a try the first couple turns would give a little cough even without ether but then nothing.
Decided to disconnect the injector harnesses just for fun and try to run it on ether. It fired right up and even started to run on its own when supplied with ether.
I have 40 psi at the fuel rail and I pulled the rail with all injectors and harnesses attached, and turned the engine over to (pointing into a container) all injectors were pulsing and atomizing just fine.
I’m at a loss of where to go next
