wont shift
tlunderwood
I just replaced the top plate..bearing and synchronize-rs. Put the transmission back in and now the shifter wont move...what happened?
The "levers" all need to be in neutral!
Sent from my DROID BIONIC using Tapatalk
Yup I've screwed that up before, take the top plate off, reach in with a screw driver and set everything to neutral and make sure the top plate is in neutral when you put it back on.
Good luck!
