Winger
- Aug 4, 2008
Wa Wa WHAT? Yeah I just ran into this weird problem... The thing wont idle for and when you put it in gear and try to accelerate it bucks and snorts! But turn on the headlights and walla! The idle speed picks up and it smoots right out! Weird! Only thing I can think of it has something to do with loading up the alternator????? Oh yeah I've modified this little 2.3L pretty heavily its a racer walsh short block the long rod short block and its got a esslinger ford SVO aluminum head and oversized valves and crower cam...... I just ended up reconnecting the EGR tube putting the 14lb injectors back in had tried 22s.
I think the TPS probably needs some adjusting as I've got it idling at 1400 right now.... It runs like a raped ape from 3000 all the way up to 6500. Oh yeah I had just added a MSD 6A also......... Hmmmmmm That was a pretty simple mod the power wire is hooked up to the hot side of the selenoid and the rest is just spliced in between the coil and the coil connector... But tha was the last mod that was made before this pesky head light idle thing! Uh anyone else ever seen something like this?
