Wo'nt Fire Now
91 ranger guy
Mississippi
I finally got the motor and tranny installed and got everything hooked up, put the battery in and now it wont fire. im not getting any fire out of the plug wires. im gettin fuel jus no spark im thinkin its the ignition conntrol module. what do u guys think?
don't just throw parts at it...
ok, I know you did the plug wires, what else did you do that could have caused this?
these things need just a couple things to fire the plugs, the crank sensor, coil packs and DIS module. make sure all of those are connected and it should have spark. just a hint, the crank sensor connects under the intake manifold above the engine mount, it's a 2 or 3 wire connector (I don't remember off the top of my head)
