AFAIK - As Far As I Know
Ok...So I called the dealership and found some information out and put it together, my torque wrench only goes to 140lbs, so I put the new crush sleeve in and the seal and I think i have it to tight now when I coast around a turn my truck hums like a jet........
so basically, you have no idea whats going on. the guy above you is right, you are not.if you torque a nut that has an already crushed sleeve behind it to 200lb lbs if will fail terrible. step 1: take torque wrench and lose it. there is no torque for a used or new crush sleeve. yes, it will take approx X amount of torque to 'crush' it, but you are not done yet. the torque required to continue on then gets easier. know what you're doing before you give advice. tightening on a used sleeve is a pathetic bandaid, that in most cases will be loose again shortly after or be too tight and eat the bearingsYou are wrong here.
There is a torque spec on that nut. It should be in the range of 160-200 ft. lbs. The preload on the bearing should already be set. The only way you would change the bearing preload would be if you crushed the sleeve more, and it takes between 600-800 ft. lbs. to do that.
When you set up the gears, and crush the sleeve for the first time, then there is no torque spec for the pinion nut, as the nut is torqued down until the preload is correct. That might be what you're thinking of.
an 8.8 and a 7.5 are about the same. they use the same crush sleeve,as does the 9 inch. and it doesnt take anywhere near 6-800 lbs. i would say in the 300-maybe 350 range.I suppose it might on an 8.8, but when I set up a 7.5 with a new crush sleeve, it didn't take anywhere near that much torque to crush it. I wasn't capable with the stuff I had on hand at the time of much more than 200-250 ft-lbs.
