wiring
scott5640
Davenport FL
my truck has a plug for fog lights behind the radio, where would the wires run to? i cant seem to find them
thats just for the switch
check if u have the plugs in the bumper
its better if u do your own wiring i guess...
the wires very likely go to the GEM(BCM) module and of course a switch, then from the GEM module it would go to the fuse/relay box under the hood for the ground of your fog lamp relay. what i do is run my own wire to the ground of the relay coil and set my switch up to ground that relay. which will then send power to the fog lamps assuming you hook the fog lamps to factory wiring
