joey74
Did ford use the same wiring in 99? WHAT IM Getting at is the door wiring the same for power windows and manual windows? ok is the wire and plug already there for power?
so how many wires for window and mirrorsThere would be 2 different wiring harness's in the dash and doors, without Power Group(manual windows) and with Power Group(power windows and door locks)
Power Group also needed added Relays, RAP Module and a different GEM module so not just wiring
If you have manual windows then there should just be 2 wires for the Door switch, turns on dome light when door is open
well my wire harness was in my moms barn and brother inlaw thought he would clean up and threw it away. I have a donor truck but when somebody took the doors they cut the plugs off and I dont know if it had the power stuff.my old doors has all the power stuff . I just need to know how many wires come out of cabremove dash from donor and wiring on both sides of firewall. install in your rig.
Ah. Now we have the context.well my wire harness was in my moms barn and brother inlaw thought he would clean up and threw it away. I have a donor truck but when somebody took the doors they cut the plugs off and I dont know if it had the power stuff.my old doors has all the power stuff . I just need to know how many wires come out of cab
Are you saying there is a wire harness in dash just for the windows and one for everything else in dash or the one in the door as the second one?There would be 2 different wiring harness's in the dash and doors, without Power Group(manual windows) and with Power Group(power windows and door locks)
